CamaroZ28.Com Message Board
CamaroZ28.Com Message Board (http://www.camaroz28.com/forums/)
-   LS1 Based Engine Tech (http://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   2000 Z28 Exhaust Question (http://www.camaroz28.com/forums/ls1-based-engine-tech-19/2000-z28-exhaust-question-874955/)
MIKEZ28AZ 07-23-2013 12:53 AM
What's the best "bang for the buck" in a bolt-on cat-back exhaust system for an '00 Z28?
cars3 07-23-2013 11:27 PM
Re: 2000 Z28 Exhaust Question
Quote:
That's like asking 100 people what their favorite color is. Everyone has a favorite brand. Mine is flowmaster and I will not buy anything else. Why, I don't know. I've been using flowmaster since 1997.
WhiteHawk 07-24-2013 08:21 AM
Best bang for the buck is ordering Dynomax 3" pipes fom Summit, Jegs, or your local auto parts store (two pieces - one behind the Y pipe and one over the axle), picking out your own muffler, and using your factory tailpipes. You can get most of the major aftermarket muffers under $200, and most of them are around $100.
You could probably clamp it all together, but I would recommend getting it welded up somewhere. With the money you save over a Corsa, you could probably buy a mig welder and do it yourself.
-Geoff
DANOZ28 07-24-2013 08:33 AM
if moneys tight the budget fix is just a high flow muffler. most people like the sound of magnaflow. i went with a fairly quiet at idle / normal driving catback edelbrock rpm. slp has a reasonable muffler. other mufflers hooker aero chamber, flowmaster. top end catbacks are borla, corsa, gmmg etc. i remember seeing a weblink with exhaust sounds. cheers
cars3 07-24-2013 10:51 PM
Quote:
-Geoff
Agree, get it welded.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
