2000 LS1 Oil Pressure Sensor on a 1998 LS1????
Old 10-08-2007, 10:19 AM
Mike96z's Avatar
Both parts are identical, both have same threads, but 2 diff part numbers, would they both work or does the 2000 sensor have a different resistance and would give me a bad reading?
Mike96z is offline
Old 10-08-2007, 01:10 PM
2001NBMZ28's Avatar
Not sure what the difference is but the '98 part number is still good, so has to be something - maybe the connector? I wouldn't take the chance using the 99-02 sensor.
2001NBMZ28 is offline
Old 10-08-2007, 01:20 PM
Mike96z's Avatar
the connectors are the same, even the threads, either its internally or they are the same, just like alot of LS1 intakes have different numbers but are all basically the same thing.
Mike96z is offline
Old 10-14-2007, 09:23 AM
TransAm9585's Avatar
98 is a different sensor. It looks almost identical but the plug is NOT the same. It roughly the same shape, but if you look down into the 98 sensor and then on a 99 up sensor you will see they are different and can not interchange. I just had to replace mine on my 98 and trust me they are different. Make sure you order for 98
TransAm9585 is offline
HectorM52
07-30-2017 11:46 AM
transam_388
03-15-2015 11:53 AM
phoenix95
01-08-2015 02:44 PM
phoenix95
01-08-2015 09:14 AM
07-04-2005 05:00 PM
Quick Reply: 2000 LS1 Oil Pressure Sensor on a 1998 LS1????
