2000 LS1 Oil Pressure Sensor on a 1998 LS1????
Both parts are identical, both have same threads, but 2 diff part numbers, would they both work or does the 2000 sensor have a different resistance and would give me a bad reading?
98 is a different sensor. It looks almost identical but the plug is NOT the same. It roughly the same shape, but if you look down into the 98 sensor and then on a 99 up sensor you will see they are different and can not interchange. I just had to replace mine on my 98 and trust me they are different. Make sure you order for 98
07-04-2005 05:00 PM
