Modified LS1 Has Idle Problem
Old 06-27-2013, 12:15 AM
ls1camz28's Avatar
I have a 1998 Z/28 Camaro with the following modifications: GM Hot Cam, Edelbrock heads, FAST 92mm intake manifold and throttle body, SLP headers, catalytic converter and oil pump.
At times, the car runs flawless. Then, at other times, it won't idle and dies when I come to a stop. It's unpredictable. I recently replaced the IAC, and I'm still having the same problem. I've taken it back to the tuner three times, and still no luck. Could the TPS be causing my idle problem?
I'd appreciate any advice that anyone has, thanks.
ls1camz28 is offline
Old 06-27-2013, 10:13 AM
DANOZ28's Avatar
Re: Modified LS1 Has Idle Problem
just a shot in the dark, after work was done on my car it was running ruff & throwing a code which turned out to be a broken wire. on the back of the intake is a sensor & a tiny wire that runs to the computer broke, cost me $100 to fix / diagnose. goodluck!
DANOZ28 is offline
10-31-2016 11:09 AM
edman
01-25-2015 02:41 PM
jayblev95
Track Kill Stories
01-15-2015 07:48 AM
BIGCOWL-IMP
11-21-2014 09:40 AM
Quick Reply: Modified LS1 Has Idle Problem
