1998 Camaro, Engine Build Up
Re: 1998 Camaro, Engine Build Up
LQ4's can cost about $1,200 and the heads are about $1,200 too so $2,400 and you're at 400RWHP on a newer / stronger engine.
If you go LQ4 you can boost later on but you wont make as much power N/A as a LQ9.
The LQX motors are basically Iron LS1's and are the same physical dimensions, have the same bolt patterns with the exception that you have to tap / drill an alternator bolt.
They might be slightly heavier but mod for mod will absolutely slaughter LS1's
Edit - Btw I forgot you will need either an LS3 or L76 intake with the L92 heads.
I was planning on boosting it and would like to get 400hp right now and add more later on. since I dont want to change engines 4 or 5 times which would be better lq4, 383 stroker, or a 408 with minor upgrades. I was also told that the lq4 and lq9 were not good for a bunch of boost because they weren't forged. do you know anything about this.
Now if you want N/A now and boost later I would go LQ4... btw if you only have a budget of $3k...you're not getting a 408 for that...
Either trans will be fine as long as they're strengthened up a bit... Auto's are always more predictable.
As for turbo's, the forced induction section would be a better advocate for that.
and really, if your going to go turbo eventually; neither of those options is that great. the ls1 shouldn't even be on the table.
I know the zr1's are rated at 638hp, and Im sure the clutches are decent; but if your going FI in a heavier f-body; get a clutch that will last. and will hold more tq. the Zr1 makes less tq than hp, and a LSx turbo car will usually make MORE tq than hp. so you see the issue.
Ive been happy with my spec stg 4, but some people have had problems with em.
looks like a company that makes an ls9 kit to work in an f-body is at around 1500? very pricey. other twin disks are a bit cheaper. textralia used to be a good one. 12-1300?
ls9 is more than 1500. damn. http://ls1tech.com/forums/manual-tra...-body-gto.html
Keep the stock flywheel. Going lighter makes launching much worse due to less rotational mass.
hotrodyou1
12-20-2014 10:05 PM
NewsBot
12-17-2014 02:50 PM
Bearmans
12-03-2014 05:28 AM
squirrels
07-13-2002 01:58 AM
