Wiring Harness Confusion
Hey Guys,
I am trying to identify the connections to my 94 Camaro Lt1
steering column harness plug. The black male pin connector has 9 wires
connected there marked location in the plug are A,B,C, D(Not used) E,F,G,H,J,K. The GM "I DID IT " column has 8 wires White=brake switch
green = RR turn
yellow = LR turn
purple = turn flasher
brown = hazard
blue = RF signal
LT blue =LF signal
black = ho
I need to know the proper connections for the column wires to the
harness connection. Any help is appreciated. Thanks.
green = RR turn
yellow = LR turn
brown = hazard
blue = RF signal
LT blue =LF signal
black = ho
Re: Wiring Harness Confusion
What year is the column from?
I looked in the 94 factory F-Body manual, and there is a diagram for Connector C216 - I/P Harness to Steering Column Harness. It is an 11-pin connector, with pins D, E, F, G, H, J, K, L, M, N, P.
I can give you the wire functions and colors, but we need to find if this it the right year and right connector.
Wires are there for:
-Key-in-ignition switch
-Key-in-ignition switch to audio alarm module
-Horn relay feed
-LF turn signal
-RF turn signal
-Hazard output
-Turn signal flasher output
-LR turn signal
-RR turn signal
-Stop lamp feed
-Horn relay feed
-LF turn signal
-RF turn signal
-Hazard output
-LR turn signal
-RR turn signal
-Stop lamp feed
OP, your life would probably be a lot simpler if you downloaded a manual.
https://www.mediafire.com/?40mfgeoe4ctti
