Wiper switch 93-97
I'm pretty sure you can service it without going pulling the wheel. There is a cover that surrounds the stalk that has to come off. Then I believe there is a screw that holds the stalk to the mount in the steering column. The stalk should just pull out, then disconnect the wire.
I haven't done this myself but I remember reading about it in the shop manual.
Warren
Warren
Warren
Warren
No The stalk goes into the wiper switch which is also the part that allows the turn signals to operate. There is a bracket that kind of holds everything in place that broke in half so now I can't use the turn signals and everything is kind of just hanging out. I fixed it once with JB Weld and some small metal strips but it broke again.
How the heck does the top of the steering column come off? My Hanies manual doesn't have any info and I cant see any way when I look at it.
I can't imagine a Haynes does not show how to dissassemble the column. If not, you need a better (like factory) manual. Steering wheel, lock plate, various and sundry items have to be removed to get down to the switch.
autoxr166
09-25-2015 04:21 PM
alliance12364
09-17-2015 08:43 AM
jackpawt883
09-10-2015 08:53 PM
