windshield washer pump wont work
hey there guys i need some help and don't know what to do. i'm new to this form stuff but needed help. i have a 1982 camaro with a 350 and my front windshield washer pump wont work. like i mean it is working the plunger part that pulls the fluid and pushes it to the sprayers is moving but isn't pulling anything fluid and don't have suction. it's a mechanical pump. please help
Re: windshield washer pump wont work
You could check by disconnecting the hose that runs to the nozzles, and then operating the pump, to make sure the suction or pressure side of the pump is not blocked. If you have verified there is no suction to pull the washer fluid into the pump, and no lines are plugged, it's very likely you need a new pump.
