Window Fuse Special?
Old 12-13-2009, 04:39 PM
MarcR94v6's Avatar
I noticed that one of my windows started getting slower and stopping only a year or less after changing motors, but when it stops I hear clicking from the fuse area. I go to look at it, and the fuse for the power windows is encased in metal and much thicker. I switched it out with a standard 30 amp, same rating as the stocker and it seems to work better. Can I keep this normal auto parts store fuse in there or do I need some special one?
MarcR94v6 is offline
Old 12-13-2009, 04:43 PM
It's called a breaker (so it can reset after it trips). You should not be pulling so many amps that it trips. Might need to replace that motor and/or check all your connections. If you end up keeping the fuse, you better keep a supply of them in the glove box.
shoebox is offline
Old 12-13-2009, 05:03 PM
MarcR94v6's Avatar
I checked it again and it was a fluke, it's the same with that fuse.
Thanks shoebox. Maybe I'll try one of those already "fixed" motors, as I don't think I can do that modification myself
Heathen1
01-02-2016 04:27 PM
ChrisFrez
03-22-2015 09:12 AM
mattstrike
03-11-2015 07:33 PM
warmeck
02-02-2015 12:44 AM
12-01-2014 08:08 AM
Quick Reply: Window Fuse Special?
