Window clamps (I dont know what they are called)
The parts that pushagainst the window when its rolled down have failed on my drivers side. When I rolled my window up on day one of them came with it. I havent taken the door panel off yet to inspect the damage, but I was just going to replace them all anyway.
Anyone have a part number or exploded view of this?
If you're referring to the inside ones, they're simply 90 degree brackets with felt pads, fastened to the top of the door frame with 10 mm bolts. The felt usually falls off. The outboard ones, IIRC, are attached to the rubber molding at the top of the door. I believe you have to replace the entire piece.
DSMKilla
05-26-2015 10:10 PM
