Fuel Sender
Old 02-02-2011, 01:58 PM
blackhawks1229's Avatar
Fuel Sender
I have 95 z28, I got it in October and learned the hard way that the fuel guage doesn't work properly. I can usually go by the mileage and I figured out that half tank means empty. Lately the mileage has gotten lower (started at 200 miles on a tank and now it is down to 130-160 or 180 if I'm lucky). Is this a fuel pump issue? I do have a small hole in my muffler, but I don't think thats it. Any help is appreciated!
blackhawks1229 is offline
Old 02-02-2011, 03:42 PM
Re: Fuel Sender
The gauge isn't very accurate, but the more typical situation is that when the guage shows 1/2-tank, you only have 5 gallons left, and when it shows 1/4-tank you are lucky to have 1 or 2 gallons.
Shoebox has a very helpful writeup on fuel level problems:
http://shbox.com/1/4th_gen_tech2.html#fuel_gauge
Injuneer is offline
Old 02-03-2011, 06:26 PM
Re: Fuel Sender
Thanks for the help!
Old 01-31-2012, 10:54 AM
Re: Fuel Sender
The other day i was starting my car up when i noticed that the gas gauge was on a 1/4 tank, i was only at 118 miles so i filled it up, and the gauge still shows 1/4. Has anyone's sender ever just stopped working? Do you know if a fuel pump replacement would work?
Old 01-31-2012, 03:03 PM
Re: Fuel Sender
Use the information in the link Injuneer provided to troubleshoot your gauge reading problem.
shoebox is offline
HectorM52
07-30-2017 11:46 AM
Jessie4tin
01-07-2015 08:53 AM
ANDYZ28
12-29-2014 09:13 PM
07-04-2005 05:00 PM
asianice25
06-13-2002 02:01 PM
Quick Reply: Fuel Sender
