what wires to jump to make window motor work Help please!
Old 04-06-2006, 12:30 PM
remaxracer45's Avatar
Unhappy what wires to jump to make window motor work Help please!
I could't find a better spot to put it so please bear with me if in wrong spot. I have a 97 ss with the window stuck have way down. if you slip the switch on and off the wire block it moves a little bit when you push the button. I just want to jump the wires to get it up and then to see if I need a motor or a swith or a wire plug. Which wires do what this is drivers side with a power window/lock/mirror car. Thanks a bunch!
remaxracer45 is offline
Old 04-06-2006, 01:44 PM
valter's Avatar
Re: what wires to jump to make window motor work Help please!
I have same problem today I don't think jumping anything will help. If it moves a little, it's probably thermo-relay inside motor disconnecting power. You can try pulling window by hand and pressing button - works for me.
valter is offline
Old 04-06-2006, 05:12 PM
We prefer that you limit posts in "LT1/LT4 Engine Tech" to questions related directly to the engine. This is the busiest forum, and off-topic posts force the valid posts off the bottom of the page faster.
I'll move this to "General F-Body Tech & Info" for you......
Injuneer is online now
Old 04-06-2006, 10:10 PM
Dark blue and brown, assuming everything else in the circuit is intact and functioning.
http://shbox.com/1/window_motor_switches.jpg
Jumping it won't help a dead motor, though.
shoebox is offline
Old 04-06-2006, 10:18 PM
Cool Re: what wires to jump to make window motor work Help please!
thanks shoebox! I do understand I am just trying to troubleshoot the switch or motor.
Old 04-14-2006, 11:42 PM
the window goes up or down a bit then stops, I have a relay of some sort that makes a clicking noise by my steering column. Is this maybe the problem? When I jump the wires on the switch no change?
Old 04-15-2006, 06:10 AM
Dave89IROC's Avatar
its the motor that is your problem
Dave89IROC is offline
Old 04-15-2006, 12:03 PM
Dave, you are sure? any ideas of an easy way to change it I allready bought one thinking that was the deal? What does that box do?
Thanks a ton!
Shawn
Old 04-18-2006, 09:47 PM
camzaro28's Avatar
[QUOTE=shoebox]Dark blue and brown, assuming everything else in the circuit is intact and functioning.
Jumping it won't help a dead motor, though.[/QUOTE
i was gonna post a new thread but then i came across this one.
last year b4 i put my car in storage i was having problems with my passenger side window goin down. my window switch panel is loose, the lil brackets broke, and i would have to wiggle the wires/switches to get the window to come down. now that the car is out of storage the window wont come down.
how would i go about making sure its the switches and not the motor? i see u talked about umping them, how do i go about doing that? put power and ground to them?
if that is the case, which one does the power/ground go to?
tia,
sorry for hijacking thread
camzaro28 is offline
Jazsun
12-29-2014 12:14 PM
siguy
11-27-2014 10:07 AM
Snoman73
11-17-2014 07:22 PM
BergerSS435
06-26-2002 11:06 PM
Quick Reply: what wires to jump to make window motor work Help please!
