What is really the advantage of an aluminum driveshaft?
#16
Originally posted by teke184
really?? you sure?
if so...i stand corrected
really?? you sure?
then go to part numbers.
its not listed, and I have yet to find anyone that says it has an alumium.
I crawled under my car and its steel. and I know he didnt change that like he did the koni's (I hate people that change parts with inferier ones)
#17
I say if you are gonna be making serious power - ditch any stock driveshaft.
I have seen a couple of aluminum ones twisted out of LS1's with not much done...just a good bite and lucky rear-end I suppose...it at the dragstrip both times. They are EXTREMELY thin though - I would think any high HP application should just get a stronger/aftermarket one.
I would still use it if I were you though - and sell the steel one - I wouldn't pass it off as useless.
#18
This largest advantage is the fact the the aluminum is balanced, your steel one is not. Swap it in there and see if you notice a difference, especially at high speed. Takes about 5 minutes to swap.
#19
I don't care about that extra few pounds............just make more power, and you won't notice your steel driveshaft.
#21
I can't speak for the 1LE shaft, but as I posted a few posts back...I've had my LPE 3.5" aluminum behind 420rwhp since 1995. and have never replaced or had to rebalance anything...plus it shed a few pounds off of the rotating mass. I know that A4s are generally easier on the driveline, but my 60's are always in the 1.60-1.70 range....over the last 10 years I've gotten my $350 worth
--Alan
--Alan
CARiD
09-30-2015 05:44 AM
