What gear oil for the rearend?
What fluids have you guys had luck with in the rearend? Should I add the limited slip modifier if the manufacturer says their oil already has it? Is the ford limited slip additive okay to use?
Normally the dino fluid requires the additive and the synthetics do not. The label will clearly state "Contains Limited Slip Additive". If it states that it contains the additive, there is no need to add more.
Not sure on the Ford; we just put some in a buddies car and it was a generic brand.
I use Royal Purple, but it is pretty pricey.
07-04-2005 05:00 PM
redz_02
07-24-2002 09:42 AM
