What is this?
What is this?
Re: What is this?
Shoebox has the info - filter/flow reducer for the Opti vacuum harness:
http://shbox.com/1/opti_vacuum_hose.jpg
Re: What is this?
What its missing is 1/4 inch rubber line, and the tiny 1/4 plastic elbow that plugs into the top air intake elbow, if you see A little hole in that elbow, then that is it, or at least that is how mine is set up, hope this helps.
Re: What is this?
The air supply line runs from the air intake elbow, where it plugs in with the blue plastic elbow, to the nipple on the bottom (rear section) of the Opti. There are no fittings other than the blue elbow in that line.
http://shbox.com/1/opti_vacuum_harness.jpg
http://shbox.com/ci/opti_vent.jpg
