Weight Reduction
Old 06-27-2005, 02:49 AM
evo.end3R's Avatar
Weight Reduction
What all parts/insulation and **** can i pull out that arent necessary? all suggestions are welcome. Also would like detailed instructions for pulling out the airbag system. Does anyone know how much weight I will save by pulling out all the insulation and foamy **** under the carpets? I would like numbers and I am interested to hear weight for all suggestions. I want to have a normal looking interior as it is a daily driver, but i am willing to pull the passenger seat/rear seats on track nights. thanks
evo.end3R is offline
Old 06-27-2005, 02:58 AM
evo.end3R's Avatar
Re: Weight Reduction
I would like to see some numbers to see if its really worth the time and effort to strip all the crap under the carpeting and behind the panels and everything
Old 06-27-2005, 06:40 AM
teke184's Avatar
check out brent franker's site, he has a DETAILED list of weights for all kinds of things...down to less than a pound.
but honestly, i think at best you could manage 50lbs without sacrificing comfort.
teke184 is offline
Old 06-27-2005, 10:31 AM
ls1tech.com has a huge thread on weight reduction. It gives you the weights, you can decide if you can live without the parts it deletes. Reducing weight increases performance, simple physics. Reduce the weight 100# and you should increase your MPH almost 1mph and reduce your ET by about 1/10th second.
http://www.ls1tech.com/forums/archiv...p/t-17319.html
Injuneer is offline
Old 06-27-2005, 05:45 PM
breakmyfootoff's Avatar
The one thing I removed that I wish I hadn't is the insulation under the carpet. Lots of road noise and exhuast noise and seems to have more rattles and such. It just made the car seem cheaper and only drops about 15 lbs or so. I'll be adding some more back under the carpet later.
breakmyfootoff is offline
brothaslide
01-09-2016 12:11 PM
95chwagon
10-16-2015 12:24 PM
NewsBot
09-14-2015 09:20 AM
karpetcm
08-14-2015 03:02 PM
bunker
08-01-2015 10:10 PM
Quick Reply: Weight Reduction
