Wats wrong??
Re: Wats wrong??
bad opti, bad plugs, bad wires, bad fuel pump, bad gas, bad sensor.....
could be many things.
does the SES light come on? have it scanned that will likely get you going in the right direction
Re: Wats wrong??
What do you actually do when you "give it gas"? Putting the pedal to the floor puts the PCM in "clear flood" mode.... which might point to a problem, if that's what you have to do. Putting the pedal partway to the floor will increase air flow and clear out accumulated fuel, but not as dramatically as putting it all the way to the floor.
Aaront810
08-29-2020 09:34 PM
