vibration in the gas pedal since changing...
serpentine belt, heater/radiator hoses.
When I put in my new heater/radiator hoses, I removed: The battery, Alt, Pwr Steering res., radiator fans, intake elbow+ cia, serpentine belt.
So I put everything back together but an alternator bolt fell and I couldn't find it. I'm assuming it still stuck somewhere since it's not on the ground. I then put my new driving belt on, bled the rad fluid and everything seems ok.
BUT, I took the car for a drive and noticed a vibration in the gas pedal from around 1200rpm to 2000rpms that I couldn't feel before I did all this work.
Any ideas on this one??? Can a bolt stuck somewhere do this?
Finding that sucker will be next to impossible unless I take everything out again.
Re: vibration in the gas pedal since changing...
I replaced the bolt with an ordinary one. It was the short one at the driver side on the back that goes through the black bracket.
Why do you ask?
Why do you ask?
CARiD
07-07-2015 08:19 AM
