Vacuum lines interchangeable? - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 11-20-2013, 12:56 PM   #1
On a 93 LT1, are the passenger side vacuum lines for the A/C and FPR interchangeable? The engine was swapped out a year ago, and I've been fighting a hard-to-start issue, and I just noticed that the shop that did the change had switched the lines to these two vacuum ports. I corrected it, but just wanted to see if this could make any difference.
Thanks!
gelbza is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
installed new opti cap and rotor, now problems Nellsw88 Fuel and Ignition 0 05-26-2015 06:55 AM
95 camaro vacuum lines Patrick Kovack LT1 Based Engine Tech 1 03-08-2015 10:26 AM
Idle surging grgguy Computer Diagnostics and Tuning 17 02-23-2015 08:57 PM
Did I purchase the wrong cylinder heads? Chris Anderson LT1 Based Engine Tech 4 01-27-2015 09:30 AM
what all interchanges between the iron and al heads Brandon Wittmer General 1967-2002 F-Body Tech 0 12-07-2014 01:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
