Vacuum gauge results- is this normal?
Old 09-08-2012, 06:53 PM
Wilson's Avatar
Bought a vacuum gauge and wanted to know if these results looks okay on a 93 LT1. Intake manifold leak was just repaired last week. Noticed the two ports have different values but both are solid and needle is steady. Are the the correct spots to measure vacuum leaks?
Hooked gauge up to passenger side where the fuel pressure regulator hooks up to the intake.
Then I tried hooking it to the drivers side port on the intake above the Pcv valve
Sent from my PC36100 using Tapatalk 2
Last edited by Injuneer; 09-08-2012 at 07:30 PM. Reason: When posing multiple pictures, hit "enter" after the [/img] tag, so they don't spread across the post.
Wilson is offline
Old 09-08-2012, 07:19 PM
Wilson's Avatar
Tried the passenger side again and got results closer to the driver side. Weird.... Is this normal?
Wilson is offline
Old 09-23-2012, 02:17 PM
OBE1 95Z28's Avatar
Re: Vacuum gauge results- is this normal?
Looks normal for a stock engine; vacuum readings will vary based on rpm.
OBE1 95Z28 is offline
Old 09-23-2012, 04:03 PM
Wilson's Avatar
Is it weird that my vaccuum gauge shows 20-21 but I still have a good oil leak on the passenger side intake manifold?
Wilson is offline
Old 09-23-2012, 05:52 PM
Dave89IROC's Avatar
Oil leak doesnt equal vacuum leak
Dave89IROC is offline
Old 09-23-2012, 08:47 PM
The crankcase/lifter valley can be under positive pressure if the PCV valve is not working, or if you have excessive piston ring blowby. The intake manifold seal that leaks oil is between the bottom surface of the manifold and the rear wall of the block. Has nothing to do with intake manifold vacuum except if the PCV system is pulling a vacuum on the crankcase.
Injuneer is offline
Old 09-26-2012, 04:23 PM
Wilson's Avatar
So, if the PCV valve is working which I recently swapped out with a new unit I could just have excessive piston ring blow by. To check piston blow by do I just remove all the plugs and do a compression check?
Is the underside of the intake manifold where the lifters are located under that much positive pressure where it causes the rear intake manifold to leak tons of oil?
Wilson is offline
warmeck
03-22-2015 06:43 PM
mattstrike
03-11-2015 07:33 PM
armedtrigger
02-24-2015 08:30 PM
99TransAmWS6
02-12-2015 07:23 PM
97z28k&N
01-09-2015 04:58 AM
Quick Reply: Vacuum gauge results- is this normal?
