CamaroZ28.Com Message Board
CamaroZ28.Com Message Board (http://www.camaroz28.com/forums/)
-   General 1967-2002 F-Body Tech (http://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/)
-   -   Turn signal/hazard (http://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/turn-signal-hazard-876730/)
Chet1185 11-09-2013 02:06 PM
Turn signal/hazard
is there just one flasher or are they separate?
95 TA
Sent from my R800x using Tapatalk 2
Injuneer 11-09-2013 05:30 PM
Re: Turn signal/hazard
You need to start using Shoebox's site:
http://shbox.com/1/flashers.jpg
Chet1185 11-09-2013 10:10 PM
i'm always on there, just didn't think too look.
Chet1185 11-13-2013 10:03 AM
Swapped flashers and still no turn signals. Just swapped my good switch into this column and still no turn signals. Fuse is good, all wires look good. Hazard lights work and all bulbs light up. What else is there that can keep the turn signals from working? Would a broken brake light switch cause this?
There is one plug under the dash that I can't plug into this column but I assuming its just for the stereo controls on the wheel.
Sent from my VTAB1008 using Tapatalk 2
Chet1185 11-14-2013 02:34 PM
No reverse lights either
shoebox 11-14-2013 11:06 PM
There are some lighting schematics on my website that might help.
1995 4th Gen F-Body Exterior Lights
http://shbox.com/1/back_up_lights.jpg
Chet1185 11-15-2013 12:13 AM
I see that the fuse is the link for both. Where does the fuse get power?
Sent from my LG-LS860 using Tapatalk
Chet1185 11-15-2013 04:18 AM
Does the ignition switch supply the power to the fuse?
shoebox 11-15-2013 10:01 AM
Anything that says "hot in run" is going to be powered through the ignition switch. It would be a simple thing to see if you have power at the fuse.
Chet1185 11-15-2013 11:00 AM
Sorry that i am a noob,
Chet1185 11-15-2013 12:39 PM
Got it. One of the prongs in the ignition switch was bent. Thanks for the help
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
