CamaroZ28.Com Message Board
CamaroZ28.Com Message Board (http://www.camaroz28.com/forums/)
-   General 1967-2002 F-Body Tech (http://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/)
-   -   Trunk latch opens with driver door (http://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/trunk-latch-opens-driver-door-874878/)
Huntmaster86 07-18-2013 07:49 PM
I'm completely new to camaros. I just traded my 97 TJ (wrangler) 4" lift on 35" mtr's w/ beadlocks for my 95 z28 6 spd t top. My question is some times when I open the drivers door, the trunk latch releases. Any ideas??
bobdec 07-19-2013 10:04 AM
Re: Trunk latch opens with driver door
Is the hatch motor actually running, you s/b able to hear it ? Does it happen when unlocking the door (you said opening) . If unlocking I would guess the keyless entry receiver could be defective. The receiver is the only place where the door unlock circuit and the hatch release circuit come close to each other. I have a stock FOB and have disconnected the wire at the hatch release motor. The darn button was so sensitive it would open the hatch when I put the FOB in my pocket when leaving the car.
GaryDoug 07-19-2013 05:53 PM
If that doesn't work, try checking the C1 connector at the keyless entry receiver module. The terminals/wires for the hatch release and left side door are right next to each other (C1 terminals B, C, and G).
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
