Transmission Issue
Old 07-21-2016, 05:11 AM
Jeff1904's Avatar
Transmission Issue
So basically when I shift in my car in any gear I get very light noise and vibration threw the shiftier during certain instances not all the the time but more often then not, it stops once in in gear but not while changing to a gear and lifting up the clutch if say I'm cruising and need to come to a stop if I push the clutch in and then make a turn or hit a slight bump the vibration and noise will be there and its kinda like a winding vibration if I still have it in gear but the clutch pushed in if I move the shiftier to neutral it goes away I have no slippage in the clutch at all to the wheels at WOT or not it doesn't affect the drive ability of the car either and the noise is very very quiet its more of a vibration to me my question is what do you think it is and what needs to be replaced?
Jeff1904 is offline
Old 07-21-2016, 10:50 AM
Re: Transmission Issue
Stock shifter or aftermarket? Stock trans mount, or polyurethane?
Injuneer is offline
Old 07-21-2016, 03:25 PM
Jeff1904's Avatar
Stock shifter and stock mounts it just started about 2 days ago and I haven't done any work to the car past month and never anything to the transmission.
Jeff1904 is offline
Old 12-30-2016, 07:38 PM
Paul94Z28's Avatar
so what was the issue?
Paul94Z28 is offline
RallyRed701/2
07-20-2015 11:18 AM
Critter
07-13-2015 05:51 PM
wildchild
09-09-2002 09:12 AM
wildchild
09-06-2002 12:07 PM
Brian-94TA
07-31-2002 02:52 PM
Quick Reply: Transmission Issue
