transmission fluid
Old 03-15-2015, 05:57 PM
warmeck's Avatar
transmission fluid
i am wondering what type of transmission fluid can i use for my 94 camaro v8 6 speed. Also where can i find the dip stick or check the fluid level?
warmeck is offline
Old 03-15-2015, 07:23 PM
Re: transmission fluid
Confusing.... your signature says you have a 4L60E, but your post indicates you have a 6-speed ? ? ?
Injuneer is offline
Old 03-15-2015, 07:45 PM
warmeck's Avatar
well that is what it said on the tranmission when i did my signature? maybe im wrong...
warmeck is offline
Old 03-15-2015, 09:03 PM
moparman's Avatar
Does the car have a clutch? Do you have to shift the gears manually by pushing in the clutch pedal while moving the gearshift lever?
moparman is offline
Old 03-15-2015, 09:20 PM
Interesting thing is both the 4L60E 4-speed automatic, and the T56 6-speed manual use Dexron-III. Automatic has a dipstick, manual does not.
Injuneer is offline
Old 03-15-2015, 09:26 PM
warmeck's Avatar
ah so where do i check to see the fluid level on a manual?
warmeck is offline
Old 03-16-2015, 06:34 AM
You take out the fill plug on the driver side of the trans, and stick your finger in, making sure the fluid is level with the bottom of the hole.
On your 94, it will say "Dexron-II".... but that was superseded by Dexron-III. The trans in the photo is from a 97.
Injuneer is offline
Old 03-16-2015, 07:02 AM
warmeck's Avatar
what tool do i need to fill that hole i dont think a regular one would work? i also noticed that my trans says dexron III on it does that mean its a earlier transmission
warmeck is offline
2QUIK6
09-17-2016 02:31 PM
CamaroSS30thAnn
09-08-2015 04:43 PM
raroz28
09-08-2015 06:10 AM
LazyLemming
08-29-2015 07:36 PM
Noct
07-14-2015 01:18 AM
Quick Reply: transmission fluid
