transmission filter/fluid change how to
Re: transmission filter/fluid change how to
A Haynes manual has a pretty decent step by step. But, in a nutshell; get the car elevated high enough and on jackstands so you can get underneath. Start by loosening all the bolts around the pan. Remove all the bolts on the rear of the pan and then evenly loosen the bolts on the front of the pan to allow the rear to tilt down and drain (make sure you have plenty of newspaper laying around). Continue to loosen the bolts on the sides of the pan also. Eventually you will get to the point where one hand is holding the pan and the other hand is unscrewing the bolts. Be careful or you will be wearing some fluid.
Once the pan is off, clean it with gas or some other similar type cleaner (no H2O) and dry the pan real good. Drops of fluid will continue to drip from the transmission while you are doing this (newspaper). Pull the filter out and reinsert the new filter and then just reverse the process.
This is not a hard job, just a messy job. Also, I had to remove a linkage of some sort on the side of the pan to get the pan off (do this first). However, this was on a 95, so I have no idea if you will have to do the same or not.
Hope this helps.
Hope this helps.
Well since I am assuming it is a 6 speed you just unscrew the drain plug in the back of the transmission and let it all drain out and then put the plug back in. Unscrew the fill hole plug and starting putting ATF in it till it is about to pour out, I'm not sure exactly how much it is. Put the plug back in and you're done. There is not a filter on the manuals.
Originally Posted by CHRISCAMARO
hey thanks that is great-i'm surprised their is no filter?
there is no filter on my M6?
is about 25k miles when everyone does it?
I change my M6 Tranny Fluid every summer. Just to keep all in good shape
