Tie Rods, Easy to remove from steering rack? - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 05-24-2013, 12:36 PM   #1
Ok so heres the scoop. The car was in a bit of an accident, and the steering rod and end snapped right off the knuckle so i was wondering. Instead of just getting a whole new rack, is it easy to just remove one of those rods? Driver side if that makes any difference.
Any and all help is appreciated, going to get parts tmrw and dont want to buy the whole rack if i dont have to.
95WhiteZ28LT1 is offline   Reply With Quote
Old 05-24-2013, 01:41 PM   #2
Super Moderator
Re: Tie Rods, Easy to remove from steering rack?
Everything pretty much unscrews - unscrew outer tie rod, remove boot (requires boot clamp tool to crimp new clamp on), unscrew inner tie rod. But the factory manual indicates you have to remove the rack to get the inner tie rod off the rack assembly, and the rack teeth have to be stabilized to prevent damage.
Might be best to pull the rack, and take it to a shop that has the right tools.
Injuneer is offline   Reply With Quote
Old 05-24-2013, 02:04 PM   #3
All tools needed are in my shop, not a problem. and i did read that it needs to be stabilized but everyone else has said they have done it without issue not stabilizing it.
Reply
Thread Thread Starter Forum Replies Last Post
D1SC air inlet options - LT1 need help/advice dbusch22 Forced Induction 3 06-06-2015 08:27 AM
SLP (Bolt-On) Subframe Connectors, 1993-02 Firebird Coupe Richardan15 Parts For Sale 2 05-30-2015 08:36 AM
*LT1 Rag Joint Eliminator Guide* Victor Lamb Suspension, Chassis, and Brakes 2 03-17-2015 12:40 PM
2002 Z28 radiator fan runs after turn off mspennyhughes LS1 Based Engine Tech 4 03-01-2015 03:50 PM
Tie Rod End Replacement - Some Quick Questions (mostly grease-related) Hurin Suspension, Chassis, and Brakes 4 12-13-2014 07:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
