Things to check before purchase? 2000 Convertible - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 01-25-2014, 10:16 AM   #1
I'm going to look at/test drive a 2000 SS convertible. Auto with 70k miles. Is there anything that I need to check out closely. Last Camaro I had was 72 RS and that was a long time ago.
U-234 is offline   Reply With Quote
Old 01-25-2014, 01:10 PM   #2
Re: Things to check before purchase? 2000 Convertible
Do a search on piston slap issues. It'll help in knowing what to listen for...to be honest, I'm not even sure if the 00's were one of the years with the isssue...
BandDirector Blk98ZM6 is offline   Reply With Quote
Old 02-28-2014, 07:00 PM   #3
TraceZ's Avatar
Take it for a test drive with the top up, windows closed and radio off. Listen for wind noise around the windows.
Check the carpeting for any signs of moisture which could indicate leaking window seals.
use your nose... does it smell musty?
Look under the car for signs of abuse. Is the bottom of the nose banged up? Is the air dam intact? Are there any signs of damage to the underbody from being jacked up in the wrong place?
Check the seats - specifically the drivers side bolster for wear from ingress and egress.
Look at the condition of the convertible top. Any rips or tears? Operate the top up and down - does it get hung up on anything?
Inspect the top of the dash - it is cracked or broken anywhere?
Listen to the radio and check for blown speakers.
Check all the fluids - smell them to see if they have a burnt odor. Is the brake fluid fresh? If it is black, it's old.
How old is the battery?
Are the tires in good shape? Are any of the rims damaged from hitting curbs?
Cold start the engine and listen to it as it warms up. Some valve train noise while cold is normal.
Drive it at least 20 minutes so it gets up to full operating temperature. Monitor the oil pressure as it warms up. Make sure it does not drop too far when fully warm.
What kind of oil has been run in it?
Move the windows up and down. Are the window motors any good? If they go really slow that indicates a weak motor.
TraceZ is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Trans issue PCLZ28 Drivetrain 7 12-24-2015 06:19 PM
1985 Chevrolet Camaro IROC-28 Time Capsule capebuf Cars For Sale 0 01-13-2015 08:22 PM
1996 Formula M6, Hardtop, Black 71K original miles Jazsun Cars For Sale 0 12-29-2014 01:14 PM
Increase number of visable 1st page topics on some boards. Hal Fisher Site Help and Suggestions 4 09-14-2002 10:36 PM
engine dress up, for wires, WIRE LOOM, CHEAP!!!! danielbmx Car Audio and Electronics 0 08-28-2002 12:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
