thermostat in boiling water question..
my car was getting hot, so i put in a new thermostat hoping for a cheap quick fix, my car has been cooler, but just out of curiousity, i put the old thermostat in boiling water to see if it would open or not, and it stayed shut, does that mean that my thermostat was bad? or is that not an accurate way of testing? thanks
Re: thermostat in boiling water question..
What is the elevation where you boiled the water? That will affect the temperature of the water. Higher the altitude, the lower the boiling point.
Brandon
The other thing to keep in mind... the rated temp of a t'stat is the temperature at which it BEGINS to open. Typically, it will not be fully open until the temperature reaches about 20*F above the rated temperature.
I was bored so I did some searching.
The Highest point in Texas is Guadalupe Peak at 8,749 feet.
Current barometric pressure in texas...is 29.9 give or take.
At that altitude water would boil at approx. 196 degs
I feel it is safe to assume that his car is not parked at the top of the peak
so we can say the his boiling point would carry a temp slightly higher than that.
Conclusion:
Busted thermostat
Man I love Google
Conclusion:
Busted thermostat
Man I love Google
I did the water test with my stocker and a 160 hypertech t-stat. The hypertech opened a lot sooner than the stock one, so the test you did is a good way to evaluate for a broken t-stat.
Conclusion:
Busted thermostat
Man I love Google
Conclusion:
Busted thermostat
Man I love Google
thanks for looking that up for me, you must have been VERY bored
thanks guys for the responses, made me feel a little bitter about it, by the way, my car hasnt been getting nearly as hot as it did that day
thanks again
Gasoline engine's operating temprature is 210*. Water boils at 210*. When fluid is pressurised it raises the boiling point. If your T-stat is rated at 180*, according to what INJUNEER said above, then your stat will not be fully opened until about 200*...It starts opening at 180*, allowing coolant to flow.....Add in the whole altitude thing and..........ok, I'm getting a headache......
I, personally, get nervous letting my car get that hot. Bad experiences w/ POS car in the past.
tdigger9899
09-07-2015 10:56 AM
