Tach wiring help
Old 01-18-2015, 03:52 PM
ldtantlinger92's Avatar
Tach wiring help
I've looked at forum after forum, and I don't know what I'm doing wrong. I have a 97 camaro z28. I'm trying to install a 5" tach. I have power, light comes on with headlights, and a good ground. But no matter where I hook the tach wire to it refuses to work. I tried the white ICM wire and the white wire in the PCM at A13. I've been stumped for days now. Any help will be greatly appreciated.
ldtantlinger92 is offline
Old 01-18-2015, 07:03 PM
Re: Tach wiring help
Maybe providing info like the brand and model tach you have will help get you an answer.
shoebox is online now
Old 01-18-2015, 10:53 PM
Sorry, didn't think of that. It's a 5" Autometer tach with shift light. Got it from a friend that had a v6 so the brown wire was cut but I soldered it together. Anyone use the crankshaft position sensor wire?
Old 01-19-2015, 09:05 AM
The AutoMeter 5" tachs are calibrated for 4 pulses per crank rev. The reluctor in the 96/97 has 4 pulses per crank rev.
Note that different models of the 5" tach can be recalibrated via different methods. No substitute for the manufacturer's install instructions......
http://www.autometer.com/media/2650-1244.pdf
Typically, you put the green wire on the coil negative. This is not recommended if you are using a multiple discharge ignition like MSD, Crane, etc. See instructions.
Injuneer is offline
Old 01-19-2015, 09:54 AM
Thanks Fred, I am running stock ignition for the time being. The coil is located in front of the driver side cylinder head correct? This is my first LT1.
Old 01-19-2015, 01:26 PM
Use this website for info on the LT1:
4th Gen LT1 F-Body Tech Aids
http://shbox.com/1/coil_loc.jpg
http://shbox.com/1/1996_ec_03_ign_system.jpg
Injuneer is offline
mr28
04-20-2016 05:44 PM
charchri4
04-14-2015 06:40 PM
Zee man
02-12-2015 07:07 AM
mr28
11-23-2014 11:11 AM
Quick Reply: Tach wiring help
