Subframe mounting
Old 12-10-2013, 03:57 PM
LeeC's Avatar
Subframe mounting
Gotta get new bushings and bolts to mount my subframe back up to the body, and I see they make the standard rubber and poly ones. My question is for those people that replaced theres. Which ones are better and from who?
LeeC is offline
Old 12-10-2013, 05:13 PM
Re: Subframe mounting
Provide info on year of vehicle and model. Appears to be a 1st or 2nd Gen.
Injuneer is offline
Old 12-10-2013, 05:40 PM
LeeC's Avatar
1st gen 69
LeeC is offline
Old 12-10-2013, 06:21 PM
As you've probably noticed, there are not many 1st Gen owners on the site. At this point I'd guess that 80-90% of the regulars are 4th Gen. Hopefully you will get lucky and get a response.
Injuneer is offline
Old 12-10-2013, 07:02 PM
LeeC's Avatar
You seem to be right about that, not much traffic on this site at all. This is my third post and not any to very little response.
I seem to be wasting my time.
LeeC is offline
Old 12-11-2013, 09:23 AM
Wild Willy's Avatar
Rubber has better compliance, rides better and quieter. Poly will be stiffer, the "performance" mod, they may squeak, and will likely ride harsher. Depends on your final use.
Wild Willy is offline
Old 01-06-2015, 03:26 PM
markaubuchon's Avatar
I have an 84 that needs them replaced. Same question rubber? Who is a good source?
markaubuchon is offline
Old 01-07-2015, 02:41 PM
Former Vendor
Kyle@SLP's Avatar
Either one is going to work for you, It seems a lot of guys mostly cruise their classics and you may not notice the benefits of the poly. However personally I've never had issues with poly making noise. A little grease helps with some sometimes too and poly seems to outlast the rubber for me. My vote is for poly.
Kyle@SLP is offline
Old 01-07-2015, 03:39 PM
1996LT1Z28's Avatar
Two excellent 1st Gen Camaro sites are:
Camaros.net
Camaros.org
I have a 69 SS, and that's where I go for all my 1st gen questions.
Mike
1996LT1Z28 is offline
Old 01-08-2015, 05:08 AM
Cam's maro's Avatar
I restored a '67 SS350 back in the early 90's. The bushings were replaced with the same durometer rubber as factory. The ride was fine. Although it wasn't a daily driver, we did bash it at the track a bit. I never experienced any unwanted frame flex or squeeks. The kit came with all the correct bolts, washers and spacers along with the bushings. For me the rubber was a better option. I can't remember the manufacuter's name tho.
Cam's maro is offline
Old 01-09-2015, 06:43 AM
Do the 3rd Gens even have the same subframe bushings that the 1st and 2nd Gens have?
Injuneer is offline
G-BODYT56
01-14-2022 11:14 PM
alliance12364
09-23-2015 12:40 PM
alliance12364
09-23-2015 06:09 AM
War Engine
09-18-2015 07:28 PM
Daluchman1974
09-11-2015 06:12 AM
Quick Reply: Subframe mounting
