steering wheel problem?
Old 12-11-2014, 01:15 PM
jj71787's Avatar
Hi everyone.
Recently my car has made a weird noise. This only happens when the car is cold, once it warms up it goes away.
When I start the car and I turn the wheel (more so when I turn right) I can hear a clicking noise.
Does anyone know what this could be?
jj71787 is offline
Old 12-12-2014, 09:20 AM
Fatdog2's Avatar
Re: steering wheel problem?
I had a bird 10 years ago and I had some work done(can't remember what)and the plastic thing that surrounds the steering shaft was rubbing against something under the hood.Have someone turn your steering wheel with the engine on and see if the plastic thing is hitting something under the hood.I had the plastic cover removed and it was fine.Sorry I don't know the correct names of the parts.Hope this helps.
Fatdog2 is offline
Old 12-12-2014, 09:46 AM
Are you referring to the "boot, steering gear"?
Courtesy of Shoebox
http://shbox.com/1/steering_system.jpg
Injuneer is offline
Old 12-12-2014, 11:41 AM
jj71787's Avatar
Courtesy of Shoebox
if he is that doesn't look like something that you should be removing
jj71787 is offline
Old 12-29-2014, 04:43 PM
JFR
JFR's Avatar
How to you remove the Boot?
Does it have a latch?
Want to inspect and can't get boot open.
thanks
Frank
JFR is offline
Old 12-29-2014, 07:04 PM
Assuming you are asking about a vehicle similar to the 95 shown in Shoebox's diagram, part #9 is the clamp that holds part #6 on.
Injuneer is offline
Old 12-30-2014, 02:15 PM
JFR
JFR's Avatar
Thanks Fred,
yes 1995 z28. Ok, will look for clamp on shoebox diagram.
Frank
JFR is offline
Airplanedoc
02-01-2015 07:14 PM
CaRParts102
12-06-2014 08:45 AM
ro2207
12-04-2014 06:18 PM
SLIMJIM
01-07-2003 11:06 AM
formula79
08-06-2002 11:18 AM
Quick Reply: steering wheel problem?
