steering columns
steering columns
so last fall someone tried to steal my 94z, retard was a loser and couldn't get it started, too bad... if he would've everyone would have heard it due to open 3" exhaust.
anyway, i bought a column from a firebird, 4th gen, forgot what year..
i went to put it in today and it's too short!!! wtf? by 2", my old one stuck out 4" of shaft from the column, new one only has 2" sticking out!!
i thought they were all the same!
does anybody know if that shaft is two peices inside? maybe i could swith the end somehow?
this sucks, i'm thinking about machining an adaptor if i can't switch the shafts somehow..
anyone got info on columns, why did they change them at all?
thanks,
mike
thanks,
mike
thanks i'll go check, man you are too awesome, i hope i can make a donation some time to you, you really deserve it! but for now there are bills to pay... they say what goes around comes around, i hope you get all you deserve!
ttl,
mike
ttl,
mike
yeah the upper is my old one....
on the new one one of the pads that bolt upward into the dash is kinda loose, you can wriggle it but not pull it out, everything else seems kosher, i may have to disassemble both to make one good one.....
what a pain, if the steel shaft pushes up during a collision then that is what happened but thats the only think that doesn't add up. everything else is the same!
shoebox
i started tearing it apart today and the end slipped further in...so i gave it a firm tug out and was able to pull it out to the correct length...
so it must have collasped.
is it ok to use now? is it on a splined slip joint shaft to extend and retract or what?
thanks,
mike
thanks,
mike
Originally posted by limige
shoebox
thanks,
mike
shoebox
thanks,
mike
jackpawt883
09-10-2015 08:53 PM
