Spark Plug Boot Heat Shields
Old 06-04-2007, 07:54 AM
scottso's Avatar
Changed the plugs this weekend - and I noticed the only two plugs with heat shields on the boots are the rear two on the driver's side. Is that right, or am I missing some?
I am also considering doing wires (I have read it is a major PITA) - I have to assume removing the alternator is a given - what else needs to be moved or removed to get some sort of reasonable access to the wire routing?
By the way - the only two major plug issues were with the passenger side rear and front. First time, entire job took 3 1/2 hours - and that was taking my time. The front one under the alternator was a REAL killer - next time the alternator comes off. The other six were (relatively speaking) a cakewalk. One poster here suggested climbing up and kneeling on the motor to allow better articulation of wrist and elbow - that really did the trick. Of course my legs and arms are very sore today!
scottso is offline
Old 06-04-2007, 09:11 AM
mzgp5x's Avatar
I have metal heat plug boot deflectors on cyl #7 and #8. I think they help. Running MSD plug wires. Had to use binding wire to hold the MSD boot (larger size) inside the deflector. I am blown so there is alot of heat there. Especially #7 location. (97ss 383 - D1). B.
mzgp5x is offline
Old 06-04-2007, 09:14 AM
OBE1 95Z28's Avatar
The stock setup only used a couple of boot protectors.
OBE1 95Z28 is offline
Old 06-04-2007, 09:22 AM
00ls100's Avatar
mine has the metal boot protectors on all 8.
00ls100 is offline
Old 06-04-2007, 02:42 PM
OBE1 95Z28's Avatar
Different setup than a LT1.
Darth_tsunami
V6 Tech
09-18-2015 01:57 AM
nikko
04-20-2015 07:56 AM
94Z28LS1toLT1
02-28-2015 08:33 PM
rjc1629
01-27-2015 10:46 AM
Quick Reply: Spark Plug Boot Heat Shields
