Spark Plug Boot Heat Shields - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 06-04-2007, 08:54 AM   #1
Changed the plugs this weekend - and I noticed the only two plugs with heat shields on the boots are the rear two on the driver's side. Is that right, or am I missing some?
I am also considering doing wires (I have read it is a major PITA) - I have to assume removing the alternator is a given - what else needs to be moved or removed to get some sort of reasonable access to the wire routing?
By the way - the only two major plug issues were with the passenger side rear and front. First time, entire job took 3 1/2 hours - and that was taking my time. The front one under the alternator was a REAL killer - next time the alternator comes off. The other six were (relatively speaking) a cakewalk. One poster here suggested climbing up and kneeling on the motor to allow better articulation of wrist and elbow - that really did the trick. Of course my legs and arms are very sore today!
scottso is offline   Reply With Quote
Old 06-04-2007, 10:11 AM   #2
I have metal heat plug boot deflectors on cyl #7 and #8. I think they help. Running MSD plug wires. Had to use binding wire to hold the MSD boot (larger size) inside the deflector. I am blown so there is alot of heat there. Especially #7 location. (97ss 383 - D1). B.
mzgp5x is offline   Reply With Quote
Old 06-04-2007, 10:14 AM   #3
OBE1 95Z28's Avatar
The stock setup only used a couple of boot protectors.
OBE1 95Z28 is offline   Reply With Quote
Old 06-04-2007, 10:22 AM   #4
00ls100's Avatar
mine has the metal boot protectors on all 8.
00ls100 is offline   Reply With Quote
Old 06-04-2007, 03:42 PM   #5
OBE1 95Z28's Avatar
Quote:
Different setup than a LT1.
Reply
Thread Thread Starter Forum Replies Last Post
Engine randomly stalls out while driving need some help here Darth_tsunami V6 Tech 6 09-18-2015 02:57 AM
spark plugs nikko Fuel and Ignition 5 04-20-2015 08:56 AM
spark plug wire #5 94Z28LS1toLT1 LT1 Based Engine Tech 3 02-28-2015 09:33 PM
97 Camaro SS ram air intake rjc1629 Parts For Sale 1 01-27-2015 11:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
