Smoking wires from steering column - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 04-13-2014, 12:36 PM   #1
So the fun continues on this 96 Z28 I bought. I was going to move the car to start working on getting the ABS and traction control lights off... I started the car, lowered the steering wheel and smoke started coming out of the steering column and it smelled like electrical parts melting. Now the check engine light is on. The car still starts and runs and everything appears to work electrically but is my only way of getting to the wires in the steering column, to pull the airbag etc..? There is another plastic piece on the column that seems to not be removable? I tried searching the forum and couldn't find the answer, so pardon my asking if I missed it somewhere. Ahhh this car gets more fun by the day.
312.Z28 is offline   Reply With Quote
Old 04-13-2014, 06:01 PM   #2
Super Moderator
Re: Smoking wires from steering column
The column may need to be removed. Check the ignition switch first. They are known to overheat and melt. The switch is not the key cylinder. It is further down the column, operated by a rod from the key cylinder. Shoebox has a guide:
4th Gen F-body Ignition Switch Replacement
I would also scan it to find out specifically what turned on the SES light. That may give you a clue to what burned/melted.
Injuneer is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
LT1 Single plane, engine management, accessories, LTs y w/cutout, ati dmpr MUCH MORE stockssn2o Parts For Sale 14 05-25-2015 09:54 AM
*LT1 Rag Joint Eliminator Guide* Victor Lamb Suspension, Chassis, and Brakes 2 03-17-2015 01:40 PM
[Michigan] Clean 96 Caprice Classic for sale BIGCOWL-IMP Midwest 0 11-21-2014 10:40 AM
*excellent info* 93 specific info list. chevroletfreak LT1 Based Engine Tech 202 07-04-2005 06:00 PM
installing steering wheel radio controls on a 97 camaro?? turbo_Z Car Audio and Electronics 1 08-19-2002 11:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
