sensor in water pump
Re: sensor in water pump
I would lower the level in the radiator lower than the sensor level and then change it. It is not that big of a deal to do, and not worth the risk of getting the Optispark wet.
Bleeding the system is not hard to do either. Go to http://shbox.com/1/4th_gen_tech2.html#radflush for procedure if you aren't familiar with how to do it.
