security light
security light
My security light came on while I was driving and stayed on for about 10 minutes. The manual said something like it could be a dirty key. Is this something I need to get serviced soon if it comes back on?
I own a 94 Z and had that prob but mine would stay on all the time. I just had my ignition replaced because one of the two wires in it that tell the pcm that the car is trying to be stolen was starting to come apart. If it would have broke completely, i would have been walking. Not that expensive to fix. Under 200$.
Yes it COULD be a dirty resistor pellet in the key (clean with a pencil eraser or very fine scotch brite). The key needs to be clean & DRY to work properly...however, when my security light came on it was due to the same issue digitalz13 experienced, except I was walking (300 mi from home too).
The light guage wires from the lock cylinder (that read the key resistor) work harden after about 100k mi & it could be 1 of them is starting to break. Mine had been hanging by a single wire strand for a while which caused hi resiatance & tripped the light intermittantly. It finally broke & the light stayed on after that. If that light comes on & stays on when the ignition is off, game over, car wont restart. If you're driving & it comes on solid, DO NOT shut the car off until you're where you want the car to be when you fix it.
It is also possible to bypass VATS (the security system) by measuring your key resistor value, getting a like value (+/- <10%) resistor(s) & jumping the two light duty wires from the lock cylinder at the steering column base. I carry a resistor as a get home fix now.
cheers,
Ian
cheers,
Ian
my security light is always on. has been since i've had the car for bout 3 yrs. but if never goes off when i'm driving it and it always starts right back up. i even had a new key made and that didnt' stop it. i guess i need to get it replaced. l8tr
Oncomingstorm22
01-22-2015 07:15 PM
fpete1992
12-11-2014 03:51 PM
JasonD
07-15-2002 02:17 PM
