Replacing hatch supports?
I need to replace my hatch supports. It looks like I need to take off the sail panels, and take the trim off the under side of the hatch to get the back parts off, or can I get away with out taking that stuff off? Also is there any special tools needed for the job? Thanks.
Re: Replacing hatch supports?
i just did it last week and with the right tool it is pretty easy. you need a torx bit i think it is the 45 or 50 if i remember right. I didnt take off any panels just pulled them back a little bit and used the other hand to turn the wrench. it would have been much easier if i had someone else to help me hold the hatch and the panels.
once you unhook the rear panel and the one in the back seat just peal the sides away and get the wrench in there.
hope this makes sense. it is pretty easy once you get in there and look at it
no problem good luck, just make sure to use a torx bit. i tried to be cheap in the beginning and use an allen wrench since i didnt own torx bits. after i finally deciced to buy them, i realized i could have done this in under an hour
10-31-2016 11:09 AM
01-13-2015 09:52 PM
