Replacing floor pans on 68 Camaro
Old 03-08-2009, 09:10 AM
xstoyz's Avatar
We are looking to replace the Floor pans on a 68 Camaro Conv. We were hoping to get an idea of what to expect to pay to have a reliable shop do the work.
Thanks for the help.
xstoyz is offline
Old 03-08-2009, 04:14 PM
Blue89Bird's Avatar
if you want good 1st gen info, this isn't the best place.
Head on over to camaros.net
That being said there's not enough information in your post to give you an accurate answer.
How are the rockers?
Do you need toe boards?
Do you need the convertible reinforcement panels?
Is the interior in the car? Does it have an exhaust system installed?
Are you going to go with a 1 piece floor pan or are you going to patch what you already have?
Blue89Bird is offline
Old 03-08-2009, 07:13 PM
xstoyz's Avatar
Blue89Bird,
Thanks for getting back to me.
I know there much of a 1st gen crowd here. But I igured I would start here. I will join Camaro.net an see if they have any input.
As for additional information I will try to explain as best I can.
The car belongs to my father in NY. He is looking to replace the floors. I really dont know how bad the rockers are. I know there is some surface rust but dont know the extent. I understand the toe boards and Conv. Reinf. Panels are ok. I believe he wants to go with the 2 piece pans(left & right). As it is now the car is a complete driver.
The reason we asked for a figure is that he got a quote for $3000 to just do the install. He would have to provide the pans as well are remove and reinstall the interior. also transport the car to and from the shop without the interior. He was a little surprised at the high cost of just the installation. We just wanted to confirm that it was infact reasonable.
Thanks again for getting back to me. I look forward to your responce.
Ed
xstoyz is offline
Old 03-08-2009, 07:22 PM
Blue89Bird's Avatar
That sounds about right if its a good shop doing a nice job.
They're going to have to cut out the old metal, then plug weld the entire perimeter of the new pieces, seam seal them, then make the bottom look as good as the top. Lots of grinding/welding/work going into it.
If you knew what I spent on sheet metal work so far on my 68 you'd cry....
http://www.j-dogs.com/Camaro should have some decent pictures.
Red97LT1
9
12-17-2014 06:13 PM
12-17-2014 11:00 AM
Hurin
12-13-2014 07:38 PM
siguy
11-27-2014 10:07 AM
Elcojoe
11-17-2014 10:27 PM
Quick Reply: Replacing floor pans on 68 Camaro
