replacing fan shroud
The whole fan assembly just rests in some hooks. Remove the radiator top cover and unplug the fans. Lift up on the fan assy to free it and snake it out the bottom around the radiator hoses. It takes a little wrestling.
22125220
Cooling - Cooling fan - Fan shroud
Fan shroud 1997
This item is Discontinued.
22125220
Fan shroud 1997
Is a junkyard to obvious a place to look? I also was attempting to show you confirmation that the reason you cannot find the part is because it is no longer available.
Magenta_Hearts
03-29-2017 08:54 PM
