questions about replacing window motor in '95 Camaro
Old 02-27-2011, 11:07 AM
  #16
Brangeta's Avatar
Re: questions about replacing window motor in '95 Camaro
Originally Posted by GONZ0
So I guess the question is: "Did you ever get your window motor replaced and the window realigned?"
Guess so haha. I think my dad was in town and did this one. There ended up being a broken metal/rubber piece that pushes against the window and keeps it from wiggling in and out.
Brangeta is offline
Old 06-16-2011, 09:42 PM
  #17
black95z0122's Avatar
Hey old thread but seems to fit.
I got to work the other day and my drivers side window wouldn't go up. I had replaced the window motor 2 years ago and when i took it out and hooked it up to a power source it worked. I suspected the thermal cut off was the problem. The motor was working too hard to move the glass. looked at the guides and they were clean. I cleaned them out when i swapped motors and they still looked good. I then tried moving the glass by hand and noticed the problem. The door has window guides. The ones attached to the outside door panel are a rubber tube with some fabric or carpet glued on them. Mine had worn down to the rubber and i think that is the cause of the resistance. The glass just sticks too much to the rubber.
Anyone know where you can get both the window guides that are on the interior door panel and on the exterior panel?
The ones on the exterior panel are i believe weld in. Has anyone dealt with replacing these?
black95z0122 is offline
Old 06-16-2011, 09:54 PM
  #18
GM. The exterior bumpers are on the rubber strip on top of the door. It snaps on/off. I think there was a thread a while back describing replacing them.
shoebox is offline
Old 06-16-2011, 09:55 PM
  #19
Thanks I'll search for it
Old 06-16-2011, 10:32 PM
  #20
Do you know what their called?.. trying to find the part #.. I've been trying window guide, window bumper door bumper with no luck
Old 06-17-2011, 06:40 AM
  #21
These parts are in the parts list on my website.
http://www.compnine.com/index.php?u=...10&grouptype=B
The sealing strip on the outside of the door is #72.
The stabilizers on the inside are #61.
shoebox is offline
Old 06-19-2011, 10:53 AM
  #22
Oh see its all one piece.. Awesome thanks a lot
Old 12-31-2011, 09:45 AM
  #23
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Is there any chance of "serious injury" when replacing the motor?
How do you replace a 1994 Chevy Camaro power window motor
BTC is offline
Steve69SS396
Track Kill Stories
15
08-10-2015 02:45 PM
Hurin
12-13-2014 07:38 PM
ChrisFrez
11-23-2014 10:33 AM
Snoman73
11-17-2014 07:22 PM
97 RedSS
06-10-2003 07:58 PM
Quick Reply: questions about replacing window motor in '95 Camaro
