qtec or Dmh
qtec or Dmh
all right guys Im looking at e-cutout. Just like some info on which one to get. its only about a 20$ difference so please let me know if you have had any problems with either of these and which one u would recommend. Thanks
I had the qtp.It works fine but rattles a bit when its supposed to be closed.It also doesn't allow a proper gasket in between it and cutout.
I just orderd a dmh after hearing they close properly so will install that shortly and see if thats true.
I also have bud with mccord 2 and pretty sure it also rattled when closed.Don't see why its so hard to design one that can't rattle when closed.
Originally posted by marv808
I have the Qtec. After 10 minutes of driving the cutout will not open when I push the switch. It will work only when my pipes are warm/cold.
then call up QTP. Something is obviously wrong. I had one, and never had that problem.
Have the DMH for over 4 years and works as good now as it did the day I installed it. No leaks , no rattles. I have seen all 3 and there is no comparison to the fit and finish of the DMH. Top notch product and customer service. I have only heard of 1 unhappy customer on this board but it wasnt because of Dave's efforts to satisfy the customer. Can the same be said for the others? Do a search and you will see what I mean. DMh rocks
