Push Button Start
Push Button Start
I am going to wire up a push button start system for my car. I was wondering if anyone could tell me what kind of switch I need. Is it just a momentary switch? I don't want to use the S2000 switch that most people use. But to my knowledge that is just a glorified momentary switch, am I right?
A heavy duty momentary switch works fine. If you are looking to hide the switch, here is a good idea.
I used the cig lighter, and cut out the back to make the switch fit. I had to use needle nose pliers to get the nut on the inside of the socket. Then I wired up the switch to the ignition wire. I still had to use the key for the acc, but the key wouldn't crank the engine. The factory lighter was the "button". It freaks people out when they see it.
The only drawback, is that the engine will turn over when the button is pushed w/o the key in, but it woun't start.
Originally posted by cndctrdj
that is the perfect answere
and it is kinda cool to push a button to make your car start
Now if your "magic button" turned everything it, that would be cool.
Originally posted by jawzforlife
I agree, but if you still have to get a key out in order to turn on the radio (as stated above) it seams kind of pointless.
come to think of it that would be kinda real neat, wonder how hard it would be, and how easy it would be to steal your car after you did that?
If you want a keyless system, just do it NASCAR style. Use a set of toggles under the dash for all the accesories, then hit the magic button. You could even wire up a KILL switch for emergencies <- (That connot be spelled right)
I will be finishing up my VW Scirocco similar to this in the summer.
Having 10 aircraft style toggles along the dash. $75
Misc. wires and connectors. $30
Pushing the "Magic Button". Priceless
$33.84 plus shipping
http://www.handa-accessories.com/s2000-03.html
You can also buy a viper switch if you don't want a honda part in your car. They cost about the same I think, thats what we put in my friends car. You can wire up the switch in series or parallel. The difference will be is series you cut the ignition wire and put the swith in the same path so you turn the key on and have to use the button. But if you just want it to show off every once in a while, just splice into the wire so you can use the switch and the key to start the car. you will still have to have the key in the ignition and on either way.
