Push Button Start
Yeah I have always wanted to also. I think that autozone/pepboys has some of them, they are kind of general application though. My friend has one on their SCCA vette and it gives it much more of a race car feeling.
do you still need to use a key after that? or is all you do is push the button? - also does this work on lt1 f-bodys, im pretty sure the ignition is the same right?
how do you still use the key? do you place it in the ignition still or what?
i wouldnt see why lt1 guys couldnt use it, i'm pretty sure the ignition stayed the same all 4th gen because i havent read otherwise but...i'm just speculating
defined
here it works like this. You tap into the 12v+ batt cord, then into the ingition wire. You put a relay on both and then attach the wires from that to the switch, so basically nothing really changes except the fact you dont have to turn the key, which wouldnt start the car anyway cause you cut the wire to the ignition lock. So instead of turning the key all the way down like you would to start, you just push the button and bamm, revvvv revvvvvv
Re: defined
