Pulley noise?
Pulley noise? 2000 SS 5.7
I just finished writing a thread about my AC problem but now I have another. Just put in a new water pump and belts. Started squeal again. I'm thinking its a pulley anyway to pinpoint which one without taking out the pump
2000 SS CAMARO 5.7 ls1
Re: Pulley noise?
You need to add a "signature" so people know which engine you have. Go to "UserCP" on the red bar at the top of any screen, left click and follow,steps to the "edit signature" screen.
Re: Pulley noise?
I did wd40 before I change the belts and even the spray that's meant to remove the noise but still didn't work. I guess I'm happy the car is running now but an annoying noise in guessing maybe gonna take off the belts and look at each pulley and see if I can locate which one, possible the one that goes to the AC and that's why my AC stopped working - kill two birds with one stone hopefully. Mine used to be at idle mostly but now actually louder everytime I step on the gas
Re: Pulley noise?
These cars are 22 years old and I ain't gonna replace the air conditioner condenser So if that's what's going out now i will disconnect all air conditioning stuff and try to find an LE1 belt to take it's place.I'll bet that's what it is.My02
Re: Pulley noise?
Not "an LE1 belt".... you need a 1LE A/C delete pulley. Whether the belt will need to be replaced depends on the specifics of the clutch pulley diameter on your compressor... appears there were two different diameters used.
Re: Pulley noise?
I'm not 100% sure but I think the Lt1 Camaros only have one belt that goes around the whole system. I remember when I had a 94 Camaro the guy said the AC didn't work so he had another belt put in that wasn't as long so it didn't go around the AC. I think with my Ls1 it has two belts, a separate smaller one for the AC.
Re: Pulley noise?
You are correct. LT1 has one belt, LS1 has two. I would loosen the A/C drive belt and see if the noise goes away. I'm thinking there may be something wrong with the A/C compressor clutch.
autoxr166
09-25-2015 04:21 PM
colts0455
13
08-07-2015 09:15 PM
