pressure test
#32
Re: pressure test
the sensor is working properly i tested it with a voltmeter i am gettin codes 14 15 26,27,70,77,84. i am going to have to the short by with a thermo tester and voltmeter but for now i will wire a fan switch in until i have time to find the short. as for the evap and egr i wouldlike advice on how to tackle that problem.
#33
Re: pressure test
You did the same with the fan relays.... you indicate the fans came on when you shorted the ALDL pins, but you have a code for a bad relay circuit.
#34
Re: pressure test
i do not know what is going on... i clearly said that the fans came on when i shorted the ALDL i also tested the fans with a wire. i then ran a scan on the car again and now i have all these troubles codes. i am going to test the wires for the CLT again and see whats going on. there is an electrical problem in this car as you can see with all the trouble codes. i would appeciate it if you could just work with me in fixing these codes. i bought a voltmeter and a thermo tester so i will be going through these codes and seeing where these bad wires are. I dont understand why you have to give me an attitude as i am still learning so cut me some slack.
#35
Re: pressure test
You're the one who seems to lack basic common sense. If you aren't happy with my "attitude", at least understand where it's coming from.
Good luck. I'm done.
#36
Re: pressure test
Hold on friend... I've spent HOURS responding to your poorly written posts. I have offered numerous suggestions, most of which you totally ignore.
