Passenger Side Mirror help - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 05-16-2013, 08:11 PM   #1
I don't know how this happened whether it's just age or someone ran past my car in the driveway and hit my mirror but it's somewhat broken off the car. Do I need to replace the whole mirror or can I somehow get the inside bracket that the mirror bolts to? Pictures are attached if they are helpful. I can take more if it somehow helps.
Thanks in advance.
Laymaster is offline   Reply With Quote
Old 05-17-2013, 09:03 AM   #2
Member
GaryDoug's Avatar
Re: Passenger Side Mirror help
It looks like it is broken, is not repairable, and is hanging just by the wires. But you should remove it to examine the mount closer to see if it can be fixed. You may be able to remove it without removing the door panel if you can reach the electrical connector behind the panel after removing the triangular piece covering the mirror's mounting screws.
GaryDoug is offline   Reply With Quote
Old 05-19-2013, 01:00 PM   #3
Gary, thanks for replying. It was just hanging on by the wires before I tried to get it back on. I believe I have it on by 1 or 2 screws right now and 1 of the screw mounts is definitely broken on a plastic mount. Is the mount something separate? Are the plastic and metal brackets interchangeable?
Old 05-19-2013, 01:13 PM   #4
Member
GaryDoug's Avatar
I have no idea. You now have more information/experience than I in this matter.
Old 05-21-2013, 11:25 PM   #5
rv93's Avatar
unfortunately, ive never taken an f body mirror off, but ive taken some other gm ones off, and they usually have 3 studs molded into the plastic. its pretty common for the plastic frame to break. The one i worked on had one broken off, and the mirror was a bit floppy, but since it was an econobox and the owner didnt wanna spend to much money, i superglued the plastic back together, and it went in fine. This was 2 years ago, and still no issues. i think its worth a shot
rv93 is offline   Reply With Quote
Old 05-22-2013, 04:52 PM   #6
RV thanks for the suggestion on the super glue but I don't have the missing pieces.
Reply
Thread Thread Starter Forum Replies Last Post
Rear of the car sags toward the passenger tire... camaro98_speed Suspension, Chassis, and Brakes 0 04-22-2015 12:26 PM
1996 Z28 Lt1 HELP!! Leakage alex5366 General 1967-2002 F-Body Tech 4 02-17-2015 11:43 PM
1996 Trans am part out siguy Parts For Sale 3 11-27-2014 11:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
