overflow tube ?
Re: overflow tube ?
That most likly is my problem bc i see the little puddle under my batt.
And air is in my system by the end of the week so i have to bleed it or im running hot . So could i just buy a hose and connect it to the metal or
will i have to by the whole assembly ? Thank i appreciate the help .
Re: overflow tube ?
You will have air in the radiator whether the rubber hose is cracked, or the metal tube is cracked. Same with the puddle under the battery - either could cause it. A lot easier to check the hose than to be looking for the metal tube, which may or may not solve the problem.
I don't know if you can buy a new metal tube, or whether you have to buy a complete battery tray/reservoir assembly.
Re: overflow tube ?
If it is the hose that is bad, you can replace the hose with a length of vacuum rated (will not collapse under vacuum) rubber hose, of the correct diameter, available at most auto parts stores. Take the old one with you so they can help you match it up.
