Oil Checking procedure
Okay okay..i know you guys will never let me live this one down..but i gotta ask ya..Is there a specific procedure for checking the oil?? I'm assuming that its a deeper sump than most motors, so do you have to run the car first to get an accurate reading?? or can you do it while its cold? Also how long do you wait after a drive to get an accurate reading?? It seems that if i check it cold..i get 1 reading..if i check it right after a drive i get another reading..if i wait 5 or 10 minutes i get a different reading..i dont think i've found a way to get a consistent reading...so what is the trick? Thanks.
Pull dipstick, wipe.
Re-insert.
Pull dipstick, check level.
Re-insert.
No?
To answer your question though, I think it's best (most accurate) to check the level once the car has been sitting for a few minutes so that all the oil has drained back to the oil pan. If you run the engine, shut it off, and check right away, you'll get a "false" low reading, because there will still be more oil up in the top of the engine that hasn't drained to the pan yet.
Re-insert.
Re-insert.
No?
haha..yea i know it sounds like such a dumb question..but i just didnt wanna check it cold..get a low reading, add oil, and be over filling it..Cuz i know on my dirtbike..if you check it cold, it wont register anything..so you could easily overfill by a quart or so, just from not using the right "checking procedure"...but okay thanks for the help. appreciate it..
Ahh sorry dude..i forget to mention an important part about the dirtbike...Its a drysump. It stores the oil in the frame. When the bike sits for a night or so, the oil drains outta the frame, through the oil line, into the crankcase. The dipstick is located on the frame. So in order to get any reading at all, you have to start the bike, and allow the oil to be pumped from the crankcase back into the frame, than you check the oil..Trust me..it scared the crap outta me when i first got it..I changed the oil, went out the next day..and there was nothing on the dipstick...than found out i had to start it first..So alright man thanks for the help.
The oil only takes about 5 min to completely drain back into the oil pan doesn't it? And when I say completely.. I mean as much that will, not ALL of it will because it will be in various passages etc.. Anyway, the highest oil reading should be after the engine has been fully warmed up and then shut down for 5 min. That way the oil has drained back but is still hot. Is that not why there is a "hot" and "cold" mark on the dipstick and the hot mark is above the cold one? (there is a hot and cold mark right?? Or have completely I lost it?)
Thats at least what I always though
teal98
15
09-16-2002 01:23 PM
danielbmx
08-27-2002 11:11 PM
johnsocal
21
08-17-2002 01:06 AM
SilverWS6
13
08-14-2002 09:29 PM
newby
10
07-27-2002 11:39 AM
