nuetral safety switch
Old 02-07-2016, 11:25 AM
frankrizz's Avatar
My transplanted Lt1 with the 4l60e transmission has a basic button type
nuetral safety switch. I can only start the car in park. I would like to be able
to use the proper switch and wire it up correctly. Any suggestions?
frankrizz is offline
Old 02-07-2016, 11:46 AM
Re: nuetral safety switch
The proper switch in a 4th gen is attached to the side of the shifter in the console. Not sure what you are really asking.
http://shbox.com/1/1995_pcm5.jpg
shoebox is offline
Old 02-07-2016, 12:53 PM
frankrizz's Avatar
Hey Shoebox, Thanks for replying. My car has an aftermarket "I DID IT"
column. Can I still use the switch you suggested or is there another set up for a column shifter?
Old 02-07-2016, 07:09 PM
You really need to start including the details of your build in your posts, specific to the question you are asking. How was anyone supposed to guess you have a column shifter?
And.... post in the correct forum. I don't know how many of these I've had to move.
Injuneer is offline
Old 02-07-2016, 09:06 PM
Well, it is made to fit the factory floor shifter. I imagine it would take a bit of engineering and fabrication to adapt it to a column setup.
shoebox is offline
Old 02-08-2016, 06:22 AM
frankrizz's Avatar
Thanks again. I will check it out.
sherwinZ28
06-06-2015 08:48 PM
warmeck
05-07-2015 02:09 PM
surreybrad
04-22-2015 06:40 AM
jmadoll
03-03-2015 10:16 AM
Hot Rod Hawk
08-30-2002 10:12 PM
Quick Reply: nuetral safety switch
